First download the necessary drivers for Windows, download here. After you've downloaded the drivers, press the red "Share" button on the camera, then plug it in.
SOURCE: Problems with Kodak Easyshare C813 Digital Camera?
In order to clearly determine the solution a fault description is needed
However please follow this link to a Problem Solution for C813
http://www.kodak.com/global/en/service/products/ekn034495.jhtml?pq-path=11888
SOURCE: My kodak easyshare c813 camera but it wont turn on
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
SOURCE: need easyshare software for windows 2003
There is no easy share version avail for your OS, the software is only avail. for winxp sp2 , vista or win 7.
You can get free download at www.kodak.com/go/edl
SOURCE: kodak easyshare c813 digital camera wont turn on ?
Having gone over a month with no response, I assume it was simply a battery problem.
