I have a "PROSCAN TV" model#32LB30H and while your watching a show it just cuts off the show and goes to a blue screen reading signal.I have to EVERYTIME go to "INPUT" and it will be on TV and I scroll down and put it on HDMI and the channel comes back on! It does it a lot!!! Other then that the picture and sound are fine.I bought this tv 4 years ago.
SOURCE: My 26
Take out the piggy back signal should solved this problems,not than ur Tuner Signal board have some kind of intermitten short in the board.Must replaced the bard.
SOURCE: blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
