Motorola Mobility Droid (2 GB) Cell Phone Logo
J
James Sides Posted on Mar 01, 2014
Network unlock code for droid 4
Need to unlock my Droid 4 for use on another network.
Choco rai
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 03, 2014
Choco rai
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
9735
Points
29
Do you want network unlock code for your motorola droid 4 mobile? Yes means you can visit this site Unlocking4u.com here you can get the code and unlock your mobile. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
http://www.unlocking4u.com/motorola-droid-4/rs6wp9/
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Mar 15, 2010
SOURCE: need to unlock motorola droid to work with my att
If this is a phone that is not branded by your service provider (example: it's a verizon phone and your trying to use it with att) you first need to make sure that it is compatible w/ att network. The phone needs to be able to take a sim card. Second, you would need to get an unlock code from the provider that the phone originally came from. Once you have that they will inform you how to unlock the phone and you will be able to use it on the other network. Be aware that since the phone is actually made for the other network that it may not work properly. This is because the phone is designed to work on a different network and will have different settings, therefore it is not guranteed that it will work to it's full capabilities, especially the internet.
Anonymous
  • 24 Answers
  • Posted on Apr 13, 2010
SOURCE: I need a manual for a Droid
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID-by-Motorola/US-EN/Documents/Static-Files/DROID_UG_Verizon_00202474c.pdf
Anonymous
  • 74 Answers
  • Posted on May 24, 2010
SOURCE: droid got wet can it be repaired...
Yes, take the battery and mem card out, get a big ziplock baggie, put it about half way full with white uncooked rice, put teh phone and battery in there and seal it up and DO NOT TOUCH FOR 5 DAYS!!!!
ismael castillo
  • 318 Answers
  • Posted on May 25, 2010
SOURCE: my droid wont unlock
DO A HARD RESET ON IT
*Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
*Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
*Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
*Use the direction pad to the right of the keyboard to select the Format option
www.usedcellphoneshop.com
rymi1982
Rymi Petros
  • 18 Answers
  • Posted on Feb 15, 2012
SOURCE: Need unlock code for Verizon motorola droid x2
try doing the manufacturing reset solution , but thats going to delete all user information and other item including contacts , resets email login user name , both TXT/MMS will be deleted , let me know if you need this solution if your not worried about the user data ok , ([email protected]) good luck
2answers
Motorola droid raze maxx locked on at&t provide
If you are asking the unlock code for an AT&T network locked Motorola Droid Razr Maxx, You can get it from www.prounlocking.com at affordable cost with easy unlocking guide.
2helpful
I need a free unlock code for my verizon droid incredible phone. Can anyone help?
If it is an HTC Droid Incredible 2 you can unlock it as it is a dual mode CDMA/GSM phone. You can unlock your HTC Droid Incredible 2 from Verizon in order to work with any GSM network. You have the entire guide here:
http://www.htcimeiunlock.com/htc-blog/how-to-unlock-a-dual-mode-cdma-gsm-phone-2013-02-23/
Unfortunately i don't know a free unlock code source but the HTC unlock service i recommended to you is a trusted one, have small prices and good support. I use it also to unlock my HTC EVO Design 4G a dual CDMA/GSM also.
http://www.htcimeiunlock.com/htc-droid-incredible-2-unlock
Unlock Motorola droid 2 To join new network
Hi, You can unlock a Motorola Droid 2 safer and easier using unlock code. You can get the unlock code for a Motorola Droid 2 from www.wickedunlock.com/motorola-droid-2/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR MOTOROLA DROID 2
1 - Switch ON your Motorola Droid 2 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Droid 2 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Droid 2 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Oct 04, 2012 • Cell Phones
Unlocking droid
You can unlock a Motorola Droid phone using unlock code. You can get the unlock code from your network provider or from any reliable online site. For example you can get the unlock code from www.wickedunlock.com at affordable cost. All the best mate.
1helpful
You Can Unlock Your Motorola . Call Your Network Provider To Ask Your Motorola Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy Motorola Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
1helpful
How do i recieve my unlock code for my droid 2
To unlock your Motorola Droid 2 MOBILE choose the make and model from their list along with the IMEI number and the network to which your phone is locked to. after that follow the instructions here mobileunlockguide , then get the unlock code mobileunlocksolutions , using the unlock code specified in it unlock your mobile safely
4helpful
7answers
Unlock code for motorola droid2 global
AsSallam o Alikum..
I want motorola droid 2 country code...
Model: A955DEC: 268435459407733074HEX: A000002275FF52I want the country code to unlock my phone..
Thank u...
May 24, 2011 • Cell Phones
3helpful
How to unlock a motorola droid global verizon?
you can unlock it and switch over to another network , if you want to unlock, you can get codes here http://www.onlinegsmunlock.com/motorola-droid/rs7wp9/
you need to specify the country and network provider
How do i flash my HTC droid incredible to Metro PCS?
Flash the Mobile using the Software Leads Data lose..So Unlock the Mobile from Network Lock use the Unlock code...
You can get the Unlock code here
http://www.wickedunlock.com/htc-droid-eris/rs11wp9/
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
