Machine was not filling due to a kink in the hose. Machine stopped showing error code 30 (overfull) despite it having no water in it. I've fixed the kink in the hose but cannot clear the error code. Hence the safety valve on the inlet hose will not open. How can I clear the error code?
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
SOURCE: ie error code
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also
error code F3E, have cleaned both hot and cold water inlet filters, also
checked drain pump and drain line, all ok. Machine drains with no
issues and fills with hot water, runs for a while then shuts down.
Any ideas?
