Name: AT&T MMS Homepage: http://mmsc.mobile.attwireless.net Gateway IP: 10.250.250.55 Port 1: 8080 Domain 1: blank Service Type 1: HTTP Gateway IP 2: 000.000.000.000 Port 2: 0 Domain 2: blank Service Type 2 WAP DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Time out: 5 Minutes CSD no 1: Blank Username: 1: blank Password 1: blank Speed (Bps) 9600 Line Type 1: ISDN CSD no 2: blank User Name 2: blank Password 2 blank Speed (Bps) 2: 9600 Line Type 2: ISDN GPRS APN: proxy User Name:blank Password:blank Should be same for internet to work. post again if not.
i just repaired a HP1955 monitor,the symptom was: when you power up the monitor,it shows on screen a desktop,but after a sec is screen going black..this repeats continously...
i just resoldered the AC cord connector on power board and also the impulse transformator...now the monitor is running good..
sry for my english,im from Slovakia
Check the MMS settings... 1. Click your Menu 2. Click Settings 3. Click WEB ACCESS 4. Click Web Sessions 5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Press the left soft key 4 times to return to the main menu. Scroll to and select Messages. Press Menu. Scroll to and select Inbox Setup. Scroll to and select MMS Message Setup. Scroll to and select Server Info. Scroll to "AT&T MMS", then press Menu. Scroll to and select Edit. Validate the following settings: Service Name: AT&T MMS Server Name: http://mmsc.mobile.attwireless.net Web Session Name: AT&T MMS
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Blank Blank or can you see shadows? If you see shadow images then the backlight or inverter has failed If it is blank blank then graphics card or connector/cable problem Does that help
