Question about Black & Decker GCO12SFB 12Volt NiCad 38Inch Cordless DrillDriver with Storage Bag and Stud Sensor
Drill has no torque when screwing or drilling.
Inherited the drill with the house that we just moved in to. The drill should have a rotational speed of what, 650 RPM? It doesn't get anywhere near that. Further, attempts to use the drill as an electric screwdriver, or even to drill, are fruitless. The drill is unable to unscrew/screw all except the loosest screws, cannot drive a screw into a wall for anything, and cannot drill holes to save its life. Attempting to drill a hole results in the speed dropping to <60 RPM, and occasionally stalling entirely. My dad is suggesting that we replace the battery, but we have two batteries and the drill behaves as described with either one. I'm not sure as to what value replacing the battery with a brand new one could have in this instance.
    Top Expert:
  • Black & Decker Master
  • 55,370 Answers
Sometimes an inheritance is not worth much.
Posted on Mar 01, 2014
6ya staff
SOURCE:
Tom
  • 221 Answers
SOURCE: damaged chuck on a a.e.g. drill, chuck is one half
Jacobs makes a couple different kinds. You say no screw inside so I would guess it is the tapered fit. It will require a couple of shims to be driven in between the chuck and head of the drill to press the chuck off. There are tools to do this but sometimes this can be done with shims. Shim each side the same and tap them in equally. If you are familiar with the pickle fork used on auto's to remove ball-joints, something like this may work as well. I hope this helps you.
Posted on Jul 12, 2010
Anonymous
  • 205 Answers
SOURCE: Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Posted on Oct 16, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: I cannot register my new 3/8 inch B&D electric drill as instructe
OK try going to Blacnanddeckercom and in the header you will find a link on the right hand side to register your new tool. Let me know if you need more assistance.
Posted on Feb 12, 2010
Testimonial: "This was not helpful at all. I went to the site you suggested and still could not register my new drill. You said to go to "Blacnanddeckercom"?"
Joe Kurek
  • 22 Answers
SOURCE: I need wiring diagram for a Black&Decker DR550
An electric meter can be used to find where wires go to switch
Posted on Jan 23, 2011
Carl Kay
  • 827 Answers
SOURCE: HOW DO YOU ATTACH A DRILL BIT TO THIS TOOL? i can
it is not a drill, it is a driver. Unless you change the chuck or add one onto it,. sorry to say., it ain't happennin...
Best regards
Ck
Posted on Mar 06, 2011
Makita DHP481 Drill will not change into low gear (1) and is locked in high (2). What could be the problem?
Gearshaft problem with the gear house
a border of small ridges which must be locked in first gear, the gear shaft that runs now through if engine is running and switch from 2 to 1 gear , the locking teeth becomes broken in the housing
126410-4 is the ordering but no separate parts to get "Do not run the machine if you switch from 2 to 1 or 1 to 2 there are 2 special springs inside the switch slide inside to switch the machine having to rotate because inside the metal (aluminium gear shaft ) that Vertaling voor is scherp getand en maakt de plastic borging kapotVertaal in plaats daarvan naar is scherp getand en maalt de plastic borging kapot is sharp serrated and makes the plastic retainer broken.
Jun 19, 2016 | Makita Drills
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
I need a switch and brushings for my HELTI TE22 Hammer Drill
You need to contact a Hilti dealer either in person or online.
May 14, 2012 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Makita 6935FD has lost all torque. The drill varies speeds when not under load, but won't drive a screw. The battery is charged. If I get the trigger in just the right place the drill will hammer once,...
Remove the brush caps and have a look at the brush length.
If they are extremely short, or barely touching the commutator bars on the armature, you will need to purchase a brush set part # (193466-2). The way you are describing it behaving without a load, and charged battery, I can only assume this will fix it. The other thing you can do is open the clamshell housing and with a pick, attempt to move the armature fan and see if it will make several full rotations. I want to know if a piece of the magnet ring broke loose and is rolling around between the armature and the magnet ring causing your varying RPM.
Nov 20, 2010 | Makita Drills
Hi i cant move my torque setting its just stuck on hammer and drill,speed ie 1 to 3 is okay but i cant get it to move to 1 to 21 is this a common problem thanks
You have an internal issue in the housing. Sometimes they will move while slowly operating the drill. If that does not work, the housing has to come apart, more specifically the head.
Jan 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Motor is burned up
Try ebay, you may get replacement part for it or else it would be cheaper than anywhere else.
Nov 05, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Jammed 2 speed switch
sometimes you have to rotate or just try to move chuck a little to align gears then try to change
Sep 27, 2009 | Drills
Black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
Sep 08, 2009 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
Dewalt 12v Cordless Drill. Same speed in position 1 or 2 ???
yep and with this model you are not alone! take it back and exchange it make sure it works before you leab]ve the shop
Jun 23, 2009 | Dewalt 18 Volt Compact Drill Kit
Electrical problem with f gs 650
sounds like dirty/loose battery connections. Try the FAQ's at www.f650.com
Feb 18, 2009 | 2001 BMW F 650 GS
Black & Decker GCO12SFB 12Volt NiCad 38Inch Cordless DrillDriver with Storage Bag and Stud Sensor Logo
97 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Thomas F. Schneider
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
