The cartridges are the correct cartridges. They do not lock into the cartridge holder. I can turn the printer off an lock them in, but when I turn the printer back on, they unlock again..
The cartridge connectors have somehow misaligned themselves. Try to pull the cartridges out as gently as possible. Ease them out slowly and carefully--don't yank too hard. Now, UNPLUG the printer. Wait five minutes, then replug and turn it back on again. It will tell you there are no cartridges or can't see them and expect you to insert the cartridges. If you have a set of old, empty cartridges handy, put them in first. Let the printer recognize them and tell you they are nearly empty. Then the printer will tell you to insert the new cartridges.
Manual, manual, manual READ it that's what it's for. Call Epson for help.
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed
at least once a week. Its less painful and expensive to just
throw the printer out and buy a new one. I recommend the canon PIXMA
ip3500. It lets you remove the printhead for cleaning unlike the Epson.
If you want to try your luck at unclogging the printer heres a link to
a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
SOURCE: C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
SOURCE: Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
