Question about Acer 22" X223w LCD Monitor
I can't open the user guide off the disc for my X223W LCD acer Monitor
  • Ray Jones
    Ray Jones Jun 12, 2009
    Repaired my prob--thanks toooooo much
  • 34 Answers
Ah.
Is there any error message?
Should be an PDF file. Is Adobe Acrobat Reader installed or any alternative PDF Reader?
Download User Manual Acer X223W (zip file)
Posted on Jun 11, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Posted on Nov 30, 2014
6ya staff
SOURCE:
Acer x223w ceramic capacitors problem
That is one of very common failure, these caps are ballast caps for the CCFL, one cap per lamp. You can get them from Mouser. The cap get expose to vey high voltage so they do breakdown. See example below.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 20, 2011 | Acer X223W Monitor
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
I turn my x223w on and in a minute its turns it shuts down, i can't get it to stay on, it like it goes to sleep
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 19, 2010 | Acer 22" X223w LCD Monitor
Acer monitor won`t turn on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 24, 2010 | Acer 22" X223w LCD Monitor
I have a x223w no sound
Spec of X223W: http://reviews.cnet.com/lcd-monitors/acer-x223wbd-lcd-display/4507-3174_7-32908354.html?tag=mncolBtm;rnav
As you can see, the monitor does not have built-in speakers. Please verify the make and model.
Apr 08, 2010 | Acer AL1917W LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Acer x 223w monitor and what video card
I have not answered the question about this problem, however someone else told me that I would have to change my graphics card to take full advantage of the features of the X223W monitor. But they did not know what I had to change it to.
Jan 18, 2009 | Acer 22" X223w LCD Monitor
Acer x223w monitor
Hi..there,
If you wanted to be crystal clear... Try using a DVI cable if your monitor got these function. Happy Holidays!
Dec 18, 2008 | Acer 22" X223w LCD Monitor
Open Questions:
Display not working, power button LED turns on blue for 1 second and won't turn on again I've searched the web as well as this site and can't find my exact issue anywhere. I hope I'm not duplicating this question though. My X223W monitor is pushing 6 years old. It was working perfectly 4 weeks ago before a 1 week trip. When I returned, I pressed the power button to turn it on. The power buttom LED simply turned on blue and then turned off after 1 second. I get NOTHING on the display itself, not even a flicker nor the Acer logo. Pressing the power button again got nothing - not even the 1-second power button light. I unplugged the monitor, plugged it into a wall outlet it was plugged into a power strip the whole week I was gone, tried the power button again, but got NOTHING. Not even the 1 second power button LED. Here is what I have tried to fix this: 1. Tried 3 different power cables that are confirmed working - nothing. 2. Tried 2 different outlets that are also confirmed working - nothing. 3. Tried unplugging the monitor, holding the power button for 10 seconds to do a reset - nothing. Although, this did accomplish restarting the cycle in which I am able to get the power button LED to do its 1 second turn on/off again. Still nothing on the display, though. 4. Took apart the monitor to look at the power supply board capacitors. None of them were blown, bulging, or looking strange at all, but I ordered a kit online to replace them anyway. When done, I triple checked my solder points, cap orientation, uF size of each cap, and re-connection of all cables - all good. But, the symptom is exactly the same. Same 1 second power button LED turning on/off with nothing on the display. Because of the age of the monitor, I think I'll likely just buy a new Acer. But, I'd love to fix this one eventually so that I could maybe end up with two displays. Is there another component I should be looking at that might cause this? Should I replace the entire power board? Is in an inverter? The logic board perhaps? Any advice would be welcome.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
See all Acer 22" X223w LCD Monitor Questions
Acer 22" X223w LCD Monitor Logo
184 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
