Go to
GENERAL ROUTERS RESETING
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button
on the back of the router for 30 seconds will reset your router to its
factory default settings. All of the settings of the router will then
be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Step 4:
Click OK.
Related Articles:
If you have forgotten your router's password, please follow the instructions below to resolve your issue.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router's web-based setup page. Pressing the Reset
button on the back of the router for 30 seconds will reset your router
to its factory default settings. Any settings on the router will be
erased and the router's IP address will become "192.168.1.1," the
username is still blank, and the password will be "admin."
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button of a Linksys BEFW11S4 router.
NOTE: If your router does not look like this, refer to the other images below:
Figure 2: Location of the Reset button of a Linksys WRT54GX router.
Figure 3: Location of the Reset button of a Linksys WRT54GC router.
NOTE: If the image of your router is different from the ones shown above, please consult your router documentation.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Administration then Factory Defaults.
Step 3:
Look for Restore Factory Defaults and select Yes.
Step 4:
Click .
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Step 4:
Click OK.
Related Articles:
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Step 4:
Click OK.
Related Articles:
