SOURCE: epson al cx11nf print problems: Lines on side of output
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
SOURCE: Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
SOURCE: Epson R230 steady 2 red light on.
It may be a general error. It is caused by cartridge error (won't read the chip), cartridge can't move back safely, or "something " slip to the mechanics. If u use the compatible chip (CISS), try to use the original chip first. The last action is turn off the printer for about 1 hour, and turn on back. It's for clearing eprom.
