SOURCE: No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
SOURCE: No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
SOURCE: Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
SOURCE: surround sound not working
sorry but start with the obvious..the surround speakers usually are a looped curcuit using one single live split .so check each speaker works the cable is ok .if all checks out ok go for the selector switch if its a push switch press it repeatedly .if all this fails tap around the unit there might be a dry joint.good luck .farr64
