the file you search for is a bios fil.Go there- http://support.asus.com/download/download.aspx?SLanguage=en-us
Select - Motherboard
Select - Socket 478
Select - p4p 800se
Select operating system(xp,2000....)
Than download the bios....ectract it.
you got the rom fil
Download a program called MemTest from here
You can get it as a bootable CD ISO or diskette.
Run it and it will tell you if you have a faulty stivk of ram
THIS MAY BE A BOIS PROBLEM, THE SOFTWARE OPERATIONAL SYSTEM WILL ONLY ALLOW TWO 2 SLOTS TO WORK IN THE MEMORY CONFIGURATION, EVEN THROUGH YOU HAVE 4 BANKS, MOST LIKELY 2 BANKS WITH THE MAXIMUIN MEMORY OF 2GB PER SLOT FOR THE TOTOAL OF 4GB OF RAM NOT 4 SINGLE 1GB CHIP SETS. YOU SHOULD TRY IT.
Using ASUS EZ Flash to update the BIOS:The ASUS EZ Flash feature allows you to easily update the BIOS withouthaving to go through the long process of booting from a diskette and usinga DOS-based utility. The EZ Flash is built-in the BIOS firmware so it isaccessible by simply pressing <Alt + F2> during the Power-On Self Tests(POST).To update the BIOS using ASUS EZ Flash:1. Visit the ASUS website (www.asus.com) to download the latest BIOSfile for your motherboard and rename the downloaded file asP4P800SE.ROM. Save the BIOS file to a floppy disk.2. Reboot the system.3. To launch EZ Flash, press <Alt+F2> during POST
