Pioneer PDP-4350HD 43 in. Plasma Television Logo
N
Norm Raymer Posted on Feb 28, 2014
I have a Pioneer Plasma TV, PDP-4350SX. The power light is on, but no picture or audio
I just moved it to another room and different HD DVR. All connections are tight, DVR is powered, can change channels with its remote, but no picture or audio on TV.
5 Related Answers
Anonymous
  • 225 Answers
  • Posted on Nov 14, 2008
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Anonymous
  • 458 Answers
  • Posted on Nov 18, 2009
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Anonymous
  • 4 Answers
  • Posted on Jan 14, 2010
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Anonymous
  • Posted on May 11, 2010
SOURCE: Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 12, 2011
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
1helpful
Stand by light flashing no picture or sound pioneer plasma 5060 hd
This is a protection error indication and the TV needs attention by a qualified service technician.
1helpful
Hello my name is joe, i have a pioneer plasma model PDP-4350SX. MFD:6/2005. friday nite i was watching tv and a loud snap came from the set and then shut off. at first i would attempt to turn on and it...
yes, the chip on the x sus or y sus board popped oven. That snap you heard is electricity arching over the dislodged chip. Common for plasmas. Call Pioneer because they may still cover it. Some manufacturers are covering it til Sept 2010.
4helpful
Green blnking light on pioneer plasma - Picture does not come on
You can try a hard reset : Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
2answers
Supply board
The power supply board for this model can be found in the link below.
Buy PDP-5030HD Power Supply Board
5helpful
3answers
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
