Columbia All Sport watch Logo
L
Lyndon Posted on Feb 28, 2014
Set time Ca002-451 - Columbia All Sport watch
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
2answers
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
1helpful
I can't set the time on my Adidas ADP6016 digital watch
There is two times possible in this watch ADP6016.
• Those times are named T1 and T2.
• IMPORTANT: When your displayed time is T2, you CAN NOT set the time but just set the offset of T2 relative to T1.
• You can see which time is displayed by looking for a very little T1 or T2 written just above the seconds
• To swap the displayed time from T2 to T1 (or contrary), you have to long press the start/stop button (top right white button)
• When your displayed time is T1, you CAN set the time with the solution given by soulgirljen
just before this one
41helpful
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 • Watches
3helpful
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 • Watches
50helpful
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 • Watches
60helpful
3answers
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
7helpful
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 • Watches
2answers
Top Columbia Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Samuel Osungbohun
Samuel Osungbohun
Level 1 Expert
Are you a Columbia Watch Expert? Answer questions, earn points and help others
