You asked this in the Mac Laptops area.
However,
To access the BIOS Setup, turn on the computer and repeatedly press the esc key to enter the Startup Menu, and then press the F10 key to enter the BIOS setup utility. Figure 1: Example - BIOS Setup Utility
The BIOS Setup window consists of options for Security, System Configuration, and Diagnostics.
Compaqs use different keys to access BIOS; try F2, F1, F10.or DEL. At the pause on startup there are usually instructions at the bottom of the screen telling which key to press for access to BIOS.
Macs do not have a BIOS to enter. The equivalent would be the Extensible Firmware Interface (EFI) to access this (Open Firmware, hence O and F key combination) press Command-Option-O-F keys during startup.
Be careful if and make sure you know exactly what you're doing.
Generally Function key can be enabled from BIOS settings. BIOS settings can be accessed by pressing DEL, F10 or F2 key at system startup (depending on the laptop u have), which is prompted at screen at startup. Give it a try
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Each BIOS has a differrent access key. Try pressing any one of these keys while your computer is starting up: DEL; F1; F12; ESC. its trial and error since i dont know which BIOS you are using, and do it quickly, dont press all at once, one at each start-up. if that doesnt work then look for the prompt to access bios and quickly press the key while windows is starting up. you need to be really quick to do this, once in bios play arround untill you find the bluetooth settings which should be under Advanced Settings. Enable your bluetooth. WARNING: DO NOT MAKE AND SAVE ANY CHANGES OTHER THAN THE ENABLE BLUETOOTH SETTINGS!!. Save the settings and procceed to start-up.
Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested: ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys. Cybermax - Press the Esc key. Tandon - Press the Ctrl+Shift+Esc keys.
