Cant Tune my Topfield TF4000T STB on a Centrex 51cm TV
Removed a Digital TV from an ariel outlet and replaced with a analogue TV and Topfield set top box and cannot find channels
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 141 Answers
Is your aerial plugged to Antenna In (not RF In)? Is the Topfield new, or a few years old? Do you see the Topfield menus on the TV?
Posted on Mar 20, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: teac hdb820
I just did a factory reset this morning and I had the same problem until I realised that you have to use the "Output" button to get the Video Outputs to DVI Digital (see page 17 of the manual), if that's what your connection is, then I could select "menu" and do a channel search. Hope this helps.
Posted on May 30, 2009
SOURCE: how do you connect a Sansui STB-HD01 (set top box)
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Posted on Aug 31, 2009
compac
Rhys Bartle
  • 10 Answers
SOURCE: Unable to rescan channels AWA STB 262 set top
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Posted on Jan 10, 2011
How do I remove a red padlock sign in the top left hand corner of my tv
This is probably from the STB what make, model is it? What model is the TV?
Jan 02, 2015 | Televison & Video
Not recieiving tv channels
Are you talking about digital, analogue or satalitte channels? Have you ran the "menu/channel/ariel or auto tune" procedure If yes and channels were found; have you tried "source input" button o your remote? Have you tried "menu/support self diagnosis or contact samsung? If all else fails contact samsung support - who I've found to be extremely helpful. Good luck
Dec 26, 2013 | Samsung 6350 Series UN55F6350 55" LED...
Panasonic viera plasma TV will not display tuning option in set-up mode. Please can you suggest how I can fix ths.
If you click on the TV button on your remote control. I believe that this puts the TV back into Digital mode.
You can also go to the Main set up menu to get into the various tuning options by pressing the MENU button on your remote. There are some devious little settings hidden away in there.
My TV was not showing that it had HDMI when I selected AV inputs...I eventually found that it was able to be restored through the MENU access.
Oct 29, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Tv will not tune using ariel
Is this for digital or analogue signals?
Have you checked the set is not switched to a direct line (AV In) input but that Tuner has been selected?
(via the remote control or manual search buttons)
Checked arial connection(s)? - plugs?
Sep 24, 2011 | Samsung Televison & Video
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
My Panasonic dvd recorder appear to no longer be receiving TV channels it was working and then suddenly not. I canstill view TV through my TV so Im doubtful that it is an ariel problem and I have checked...
Sounds like the inbuilt ATSC tuner has failed; if this is analogue only, it may not be worth repairing that. If however it is a digital tuner, it may not be economical nor cheap to replace at component level. It is up to you, if you want to submit this unit to an authorised Panasonic service centre, to get a quote and second opinion about it. At least then you could make a firm decision afterwards.
The DMR-EZ27K was a reasonable model Panasonic DVD recorder, and it's better than their DMR-ES15V.
Nice unit. The cheapest option I can suggest would be if it is an analogue tuner model, simply connect an external digital set top box to the respective inputs on the unit and record the TV that way (assuming the channels are not encrypted with macrovision). It's crude, but it will save you an expensive workshop hassle.
Mar 16, 2011 | Panasonic DMR-EZ27K
Have tried with different ariels and still cannot get any digital channels on tv can get analogue with a struggle tv keeps telling me no signal
First check there are digital channels come in your area?If yes then select digital channel to auto tune. If still have problem then need to replaced tuner.
Nov 04, 2010 | Televison & Video
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
