If you have a problem with your beko oven not heating then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
If fan is working ok, then I would suyggest that you check the fan oiven element, as it it sounds as though this is faulty.
Please rate my solution.
Thanks.
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
1. Faulty thermostat. 2. Faulty thermal cut out switch. (controls power to cooling fan). 3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat. To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components. When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present. If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
