Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
