When charger is connected, no indication light on the system. But system can power on without battery.
SOURCE: HP elitebook 8530p with Vista business wont get
PRESS F8 TO GO TO EXTRA MENU THEN DO A FULL SYSTEM RESTORE OR SYSTEM RECOVERY
SOURCE: HP dv6640BR AC/DC power supply though the battery connector
If I remember correctly, DV6000 series laptops have a modular power connector, meaning that if you pull the laptop apart you can just simply replace the power port as opposed to having to solder it on. Typically this part can be bought on ebay for about $20-30.
Even if there was a way to get your laptop to power through the battery port, that would be dangerous and probably just blow out your motherboard completely.
SOURCE: how to install the iMobile 4 Series Chipset Intel
well i found a web site, where u can get ur required stuff...
check it out
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2887&DwnldID=14617&lang=eng
select download & after it completes, just double click on the downloaded file. & simply follow the instructions;.
After its installed, just restart ur machine.
Hope its done
If u like my post, please rate me up, i really need some good ratings..
Thanks
SOURCE: HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
SOURCE: some malfunctions experienced on my hp elitebook
If you did a clean install of the OS, you need to re install all your drivers, unless the windows 7 you installed is specific to your computer and has all the drivers/software (a reload disc) included.
Your drivers are here. You need to choose the exact version of Windows and then download and install them
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3782359&lang=en&cc=uk&prodTypeId=321957&prodSeriesId=3782310&taskId=135
