SOURCE: suround speakers and center speaker is not working
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
