What type of beeping are you hearing? If you are hearing a beep every seven seconds from a handset, the solution is to recharge the battery. If the battery won't hold a charge, then replace the battery with a 5-2721 Nickel-metal Hydride battery.
The handsets can also beep for about 2 minutes if another handset or the base pages them. This is a locator tone. Just press the Talk/Call Back button or the Tone/Exit button on each handset.
that is probably your mouthpiece, it is located on the lower end of your handset and you have to open unit first to have it replaced. you could check that it has contact and nothing is blocking it before replacement.
The GE Cordless Phone
brand is designed to deliver the conveniences of cordless home service
with quality sound and features. There are many models of the GE
Cordless Phone. The most current models, including the DECT 6.0, have
standard features such as call waiting, caller ID, visual ring
indicator, phone number memory and digital answering systems.
Before You Start
Before you use your GE Cordless Phone, ensure that you have all the
parts. Your cordless phone package should include the phone base, a
handset battery pack, a battery compartment cover, the cordless
handset, a wall mount bracket, and a telephone line cord and AC power
adaptor. Once you have confirmed that you have all of your parts,
insert the handset battery pack into the handset and replace the
battery compartment cover. Insert your telephone line cord and the AC
power adapter into the phone base. The phone base identifies the
telephone line as TEL LINE and the adapter as AC. Plug the phone base
into the electrical socket. Place the cordless handset into the base.
Allow the phone to charge for at least 16 hours before its first use.
Failure to fully charge the battery before its first use will result in
poor battery performance.
Phone Setup
Once you have fully charged your phone, you can proceed with setting up
your phone's features. If your cordless phone includes an answering
system, complete this setup process first. Turn on the answering system
by pressing the on/off button. The message indicator light will
display. The cordless phones
are defaulted to English as the selected language. To change your
language preference, press the "Skip" button for two seconds. The
language will change to Spanish. Next, you will set up your voice time
and day stamp. While the answering system is on, press the "Answer"
button on your handset for two seconds. The phone will enter the
answerer mode. Press the "8" key. This will take you to the time/day
setup menu. Use the number keys to set the hour and minutes. Use the
volume up and down arrows to set the AM/PM. Press "#" to save. The
cordless handset will also require that you give it a name. Press the
"Mute" button for two seconds until the handset reads "ENTER NAME."
Enter the name of the handset by using the touchtone keypad. Press the
"Mute" button to save. Enter the default area code by pressing "Mute"
until the phone displays "AREA CODE." Enter your three-digit area code
and press the "Mute" button to save.
The Basics
GE Cordless Phones are designed to be simple and convenient to use. To
place or answer a call, press the TALK button. You can pre-dial a
number by dialing the number before pressing the TALK button. When you
are ready to make the call, press TALK and the phone will dial
automatically. To answer a call that is waiting on the other line,
press the FLASH button. If you experience call interference or bad
reception while on a call, press the CHANNEL button until your line
clears.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
After talking with Thomson Inc today your best bet is to get rid of the phone. I found out today this phone has a real problem as I see it. I can use my handset on other bases. So that means anyone with this model handset can access your line. Thomson agreed today that this is possible. All I got was a SORRY!
You have to unplug everything, take the batteries out of all the phones, wait ten minutes and then plug everything back in. Mine does this once or twice a week... they won't give me my money back.
