Fuel Gage
The IPC displays the fuel level as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the fuel level percent. The BCM converts the fuel level percent into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The fuel gage defaults to E (empty) if:
The PCM detects a malfunction in the fuel level sensor circuit.
The BCM detects a loss of class 2 communications with the PCM.
The IPC detects a loss of SPI communications with the BCM.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
DTC P0462
The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the body control module (BCM). The BCM converts this data and sends a fuel gage percent deflection to the IPC via the serial peripheral interface (SPI) in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics.
Have
For the DE 100 series radio, complete the following procedure, using a scan tool, in order to properly set up communication:
- At the Main Menu screen, select: Diagnostics.
- At the Vehicle Identification screen, select the following options:
Model Year
Passenger Car
- At the System Selection Menu screen, select: Body.
- At the Vehicle Identification screen, select the Platform type.
- At the Body screen, select: Radio.
- At the Radio screen, select: Special Functions.
- At the Special Functions screen, select: Radio Setup.
- At the Radio Setup screen, press ENTER. The following test will set up a new or existing radio.
- Select one of the following options:
USA/Canada
Export
- Press the ENTER key.
- Verify that the scan tool displays "Test in Progress."
- Verify that the scan tool displays "Test Completed Successfully."
- Press EXIT on the scan tool.
Important: The radio set up will configure the following systems:
LEARN VIN
Diagnostic Trouble Codes
Class 2 Radio Messages
Country Code
Chime Volume
Chime Level
12/24 Hour Clock
Without learning the VIN, the radio will display a locked message (LOC).
The radio setup procedure will also clear the following messages:
CAL
CAL ERR
CALIBRATE
