When the washing machine will not spin, this may not be due to a fault on the machine. It may be due to the electronic balance check.
The electronic balance check ensures that the clothing is balanced inside the washing machine before the appliance starts to spin. This prevents your washing machine from being subjected to uneven loads, which can damage the machine.
The electronic balance check also means that your washing machine will not be able to spin a single garment or a few garments because it is unable to balance the machine. If the imbalance exceeds 0.5 kg, the spin function will not operate.
In the case of a single garment or a few garments, there will be nothing wrong with the washing machine. You can work around the problem by placing a few towels in the washing machine. Towels help the washing machine to balance the load and spin.
You can test your machine by spinning with an empty drum (without any garments). If this works, the machine is working properly.
Overloading the machine can also cause the machine not to spin.
If none of the above suggestions resolve the problem, we recommend contacting an Authorized Service Center.
Rinse hold selected:
If rinse hold is selected, the washing machine does not spin at the end of the cycle. If there is water in the machine after washing, select and start a pumping cycle.
Level:
If the appliance has not been installed so that it is level, it may cause the machine not to spin. To level the appliance, adjust the appliance's feet and check it with a spirit level.
Unstable base:
If the base on which the machine is placed is unstable, e.g. a wooden floor (not a solid level base), it may cause the machine not to spin. If the base is not level or firm, movements may occur in the machine which prevent it from balancing itself.
Dirty filter:
If the drainage does not function properly, it may cause the machine not to spin. Clean the drain filter and the pump blade (if the pump blade is visible, turn it using a pencil and remove any fluff or foreign objects). Then refit the filter and start a hot wash without any soap to clean the machine. Check if the drain hose is set at the proper height (min. 60 cm - max. 90 cm) and if it is not put too far down into the drain (max. 10 cm).
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
