Region code 4 on Samsung DVD-VR355 player/recorder
How do I unlock the Region code 4 on this player so I can play DVDs with all codes? Thank you, Christina Weate The DVD/VCR player/recorder is the DVD-VR355
When you put the TV on what state does it have to be in. Because when I press menu the menu comes up i then press 76884, and the only thing that happens is that the numbers change on the right ha side of the TV, from there it is a mistry. Please help.When you put the TV on what state does it have to be in.
You can't post conmments that contain an email address.
Re: Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units. Christina Weate
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
Go to videohelp.com and search on the model number - the sequence of remote control keys to press to change the region code is there. It worked well for me, so I could play US DVDs on my UK region machine.
remove dvd switch on press dvd button press menu press 57538 a number will appear in top left corner i.e. 2 then press 9 for multiregion press open switch off player should be multi region now
If it doesn't work replace the five digit code with one of the following:
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
