Frigidaire FEF336BC Electric Kitchen Range Logo
A
Anonymous Posted on Feb 25, 2014
Hotpoint UE89X keeps turning itself on - Frigidaire FEF336BC Electric Kitchen Range
My Hotpoint ultima super silent dishwasher blocked in the night and tripped the fuseboard. I have cleared the blockage but whenever I turn the mains back on it keeps tripping the fuse before it can resume...
also check for a burned heating element, once you locate the element in the lower dish washer look i over for damage , you could also remove the wires from the lower element and then try ad see if it works ifthe unit works
replace the element
you have a short somewhere just trying to eleminate some items
Hotpoint BF1620 dishwasher will not turn off only at socket. noise is like the continual pump of emptying dishwasher. tries changing programme, turning on off, keeps turning itself on and pumping
There is a malfunction of the washer controller. Hence the mode is not shifting off from the pump as it does not end the programme. Hence you will have to confirm the output of the controller if the drive is short or functioning by itself. Since even after changing the prog there is no change the controller must be replaced. Be sure to clean the pump to see if the drain is working fine. Try this out and hope you get the fault.Good day
2answers
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Hotpoint w440 washer/dryer keeps repeating cycle load?
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
3helpful
2answers
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
2helpful
HOTPOINT AQUARIUS WF440 BEARING REMOVAL/REPLACEMENT
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
