HI
please find the ans.
Features
- Firewall protection for your network
- Parental control to supervise Internet activity
- Works with wireless 802.11b/g adapters
- Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
- Secure wireless network using advanced
- WEP, WPA, or WPA2 encryption
- Easy to get started with D-Link Quick Router Setup Utility
Description
The
D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications
Technical Specifications
Standards:
IEEE 802.11n (draft)
IEEE 802.11g
IEEE 802.11b
IEEE 802.3
IEEE 802.3u
Device Interfaces:
4 10/100 LAN Ports
1 10/100 WAN Port
Antennas:
Dual external 2dBi Gain reverse SMA antennas
Security:
64/128-bit Wired Equivalent Privacy (WEP) data encryption
Wi-Fi Protected Access (WPA, WPA2)
Advanced Firewall Features:
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec
Device Management:
Internet Explorer v6 or late
Mozilla Firefox v1.5 or later
Java enabled browsers
Leds:
Power
Status
WAN
WLAN (Wireless Connection)
LAN (10/100)
Internet Status
Power Input:
DC 5V 2.5A, through external power adapter
Dimensions:
193 x 116.8 x 30.5 mm
Weight:
940 grams (0.7 lb)
Operating Temperature:
0ºC to 40º C
Storage Temperature:
-20ºC to 65º C
Operating Humidity:
10% to 90%
Storage Humidity:
5% to 95%
Certifications:
FCC Class B
IC
CE
