Question about 2001 Mercury Cougar Cabin Air Filter
2001 Mercury Couger V6 vacuum pipe from module under battery is not connected
I just bought this car, and while ideling, the engine races and then slows. I suspected a Vacuum problem, and on inspection found the pipe from the module under the battery is not connected at the other end. I can't see any place that it should connect to. One end goes to the module under the battery tray, where does the other one go?
    Sergeant:
  • 357 Answers
Best suggestion is to get a Haynes repair manual that covers your car. There are vacuum diagrams in these books that should points you in the right direction. Given that it idles in a rather manic/depressive manner, I'd look to the carb/TBI/Fuel injector system for a vacuum nipple.
Posted on Mar 23, 2014
Anonymous
SOURCE:
Car has a bad ideling. When car idels and u try and remove the oil cap car cuts out.What can be wrong .
hi.it can be a vacuum leak at your brake booster pipes or booster self or intake manifold.it can also be a misfire on a cylinder.if you remove oil cap ideling will change because in newer engine models there must be a certian amount of vacuum inside engine by removing cap its values change.hope this helps
Jan 16, 2016 | Cars & Trucks
Petrol Car Engine OFF when Press Escilator
Have you checked the timing? It might be too advanced. I would try to retard it just a little. I would also check for vacuum leaks in any of the hoses going to the carburetor or the distributor.
Apr 22, 2017 | Maruti Cars & Trucks
When starting it sputters then races,when first staring when idel it idels down 3 to 6 rpms then races
First thing,Pam,I'd clean the MAF sensor with brake cleaner spray, after of course, checking for the vacuum leaks which cause so many idling problems. (:^) don-ohio
Oct 23, 2011 | 1999 Chevrolet Silverado 1500
My 2003 grand prix gt failed emissions and I was informed that the code stated was due to a mis fire. I also brough tmy car to a mechanic who changed 2 of the o2 sensors as well as some wiring and still...
it could be something as simple as a bad vacuum line came loose, follow the vacuum line chart placed on the inside of the hood and inspect the lines and connections themselves
May 04, 2011 | 2003 Pontiac Grand Prix
Start the car and it iddles fast and than slow as it does this it smokes out of the tail pipe and than dies.
you have water in gas your going to have to drop gas tank and clean or you can try gas cleaner maybe that will fix the problem.
Feb 14, 2011 | 1999 Audi A4
My 1994 buick road master out of California get only 16 MPG. I had a 1992 buick roadmaster out of north carolina that averaged 28 MPG. How do I get the 1994 car to get better gas milage. My machanic say...
Things that can be wrong as long as the car rools fine are the timing chain and exhaust restrictions or leaks. Dirty or leaking fuel injectors can too if the car has good power and doesn't lag at off idel ( like a timing chain loose will do ) oil pressure or too heav oil or oil that hasn't been changed. low tire pressure is worth about 3 MPG Timing chain can be 10 easy as stopped up exhaust. the car runns stronger with the pipes unbolted from the engine then theres a converter or muffler problem. If the pipes are good it'll not make any different except it'll sound like a race car. ( might seem faster but it will be faster if the pipes are stopped up. Race cars go faster with open pipes as the engine has been modifed to run better with open pipes but an ordianry car will have little difference until it's revved up real high.
Jan 28, 2011 | 1994 Buick Roadmaster
After starting, idle will not drop below 1500 rpm engine races. apparent vacuum leak. how do I locate this leak?
Easiest way to check for a vacuum leak is to spray some carb cleaner where you suspect a leak and engine idle will change.
I suspect your problem is with the IAC. Try changing if you can't find a vacuum leak. Cheaper to check for leak first.
Oct 24, 2010 | 1995 Ford Mustang
Let our Experts solve your "when at idel rpms quikly drop and car stalls" Problem
Almost always a vacuum leak. Especially suspect is the vacuum "boss" located near the back of the engine. Make sure all those little hoses are on their nipples, and that the hoses themselves are not cracked, etc.
Mar 13, 2009 | 2004 Ford Freestar
2001 Mercury Cougar Cabin Air Filter Logo
73 people viewed this question
Top Fram Vehicle Parts & Accessories Experts
txslim55
txslim55
SriPhi
Daniel Youngman
Daniel Youngman
Are you a Fram Vehicle Part and Accessory Expert? Answer questions, earn points and help others
