Universal EasyCAP USB 2.0 Audio/Video Capture/Surveillance Dongle Logo
Jessica Garcia Posted on Feb 25, 2014
My easycap isn't recognizing any of my devices
2answers
How To Install EasyCap On Windows 7
easycap was not meant to used on windows 7 (i think). but i have uploaded all my easycap drivers for you,.... as always right click exe's and in compatibility mode for windows xp service pack 2. if it still not working after driver install go device manager try update drivers from there.
easycap reccomend - ulead video studio for video editing.
the rar file has no passwords. easycap driver and stuff
3helpful
Windows7 64bit & EasyCap directions
In my experience with the Easycap software the quality of sound & vision is very poor. My recommendation is as follows:
1) Use windows movie maker instead to capture video.Use the 2M byte/sec capture rate. Make sure the box for "make video clips" is NOT selected - you probably don't want your vid chopped into little bits.
2) In my experience USB audio is rubbish on these devices, so instead connect your PC or laptop audio LINE IN to your sound source. Don't forget to set sound source in RECORDING section of Control Panel Sound devices to Line In instead of your Easycap (which the Easycap drivers would have preset it to by default).
Good Luck.
2answers
I have easycap capture device DC60 but the cd supplied will not load on to my computer.I have disabled the firewalls etc to no avail. I have vista on Ei systems acpx86 32 bit have you any suggestions....
Have you tried finding the right drivers for the device?
Once the drivers are installed, the device should work fine with all software that supports video capture, including movie maker.
2helpful
Windows7 wont recognize easycap driver
EasyCap has not released drivers for Windows7 yet and I'm not sure they will. I'd try DAZZLE or something similar. EasyCap has NO customer support. I had one of these a while back ended up throwing it in the trash can....
3helpful
My EasyCAP doesnt work!~
hi there,
if your usb port is not recognized by your computer anything you want to install in your usb will not function,try to check your usb on device maneger and updated your driver through website,
if your game controler is not recognized by your computer go to control panel click game controler and add your device follow the wisard instruction and install your controler,controler is plug and play device.have a nice day,regards
1helpful
2answers
Have EasyCap video capture device and vista x86
I have windows vista and my drivers load fine. Plug in the unit and the drivers load. I have the 4 camera easycap and the VCR easycap. Install drivers first before plugging in the unit. Restart computer, plug in unit, check device manager if there is a stk1150 loaded under image. My problem is getting small files from the recordings. I converted 2 mins of my daughters dance solo and it turned out 1.7gb AVI file without sound. Changing the options to mpeg or WV files will crash the program becuase something doesn't match. I need to play with it more to understand it better.
Top Universal Computers & Internet Experts
Paul Carew
vince
 Grubhead
Grubhead
Are you an Universal Computer and Internet Expert? Answer questions, earn points and help others
