Now I don't know if its 110 or 220. It looks like the smoke was coming from the relay control board.
I have to asume the wiring connections had not changed since it last worked.
There are three versions. LX18, LX18C and LX18H.
Inspect the relay board for damage. The connections can come loose and melt relays.
It could also be the wash sump tank heater or the booster heater if it's an H. The other two only have a sump heater. If you power it on, and have no water in it's tanks, the elements can glow red hot till they trip the high limits.
SOURCE: hobart lx18
$0. Clean the probes. Two in back right corner. Two under the front screen. Use a green scrubby.
If the problem persists, check where the water comes into the machine. There is a screen on the hose that clogs up and starves the machine for water.
SOURCE: Hobart LX18 E4 Error. Where can I get a manual?
this is asensor error unit not filling fast enough or loose connection
SOURCE: Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
SOURCE: hobart lx18 no power to detergent pump, during the
you have to go into program and activate the detergent pump.sounds like somebody deativated the det. program
SOURCE: Leak in the recyling tube on our Hobart LX18
that is called the wash pipe the part# for the pipe is 893457. that can be bought @any hobart office in your area
