Gas pressure for 1996 royal star
That is an interesting question but it would be totally dependent on where you might be trying to measure it which is not necessary anyway. The 96 RS has 4 28mm constant velocity Mikuni carbs. the fuel is delivered to the carbs from the tank through a petcock to a small pump located under the seat. The carbs are not really pressurized as much as "fed" so any positive pressure from the pump will work. When it is pumping it has very audible "clicks" that you ought to hear each time you turn on the key with the kill switch on. These pumps run on different voltages, different speeds, and are triggered by diaphragm pressure inside the pump, they are not adjustable and either work or not so there is really no fuel pressure measurement that you could take that would mean anything.
