"F20" is a No Water Detect error code. The following link explains:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
Read through the link provided and check the obvious things first. This is an error code that can have several causes, so you will need to follow the steps provided.
If you still have questions, or require additional assistance, please let me know. I hope this helps you.
SOURCE: what does the f20 code mean
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
This is one of those error codes that can be tricky to troubleshoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first, such as making sure the water taps are turned on sufficiently, the inlet hoses aren not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
For the more complicated potential causes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
SOURCE: Fault code F20 on kenmore he2t clothes washer
I had the F-28 code error on my 1-1/2 year old Kenmore HE2t. The door wouldn't unlock and I couldn't get the clothes out of it.
The repair tech, after calling other repair techs, decided it was the central electrical unit, page #8540540 (Whirlpool) -- now Part No. W10163007. I ordered it online for about $250 cheaper than the tech was going to charge (not including the additional labor charges).
