XQG65-908E
Power up the machine and press TEMP, FABRIC SELECT, TEMP, FABRIC SELECT, in that order, within 30 seconds of powering up the machine, this will enter service mode and t01 will display on the control panel...
Hold in the delay button for 3 seconds, this should reset the codes....
If doing the above does not work after 3 attempts, there is a fault in the circuit relating to the fault code,,,(COMPONENT) good luck. the code is a stuck door. Hopefully you didn't try to pry it open.
