SOURCE: oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
SOURCE: Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will
help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at
our website
1 how to remove your oven door for cleaning
or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps.
Remember to send us an email if you can’t
find the part you need.
We also supply all the Parts you need for Repairing your cooker
oven Door.
Oven
Door Hinge Spare Parts
Oven Door
Glass panels
Cooker
Door Handels ETC
Cooker
Door Catches ETC
Cooker
& Oven Door Seal / Gaskets
Remember to Leave feed
Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section
http://www.apart4u.co.uk/video-tutorials.html
