Question about Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
I need serial number off of a 1994 yamaha waverunner
I need to do a title search
Anonymous
SOURCE:
Anonymous
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
Anonymous
  • 948 Answers
SOURCE: yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Posted on Jul 12, 2009
Anonymous
  • 67 Answers
SOURCE: need to reverse lookup a 9digit serial-number
The serial number IS the V.I.N. goof ball(Solution # l ). US DOT did not require full 17 digits VIN until 81-82 on motorcycles. A knowledgeable Yamaha dealer can look this up. 1974 Yamaha TX500A.
Posted on Feb 16, 2010
heimlich
David Belcher
  • 1978 Answers
SOURCE: Bike was stolen have title
On Yamaha motorcycles the frame and engine numbers are the same.
Posted on Oct 06, 2010
Daniel
  • 123 Answers
SOURCE: 1989 yamaha waverunner. I purchased
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
Posted on Aug 12, 2011
I know the serial number ,does it tell what year the waverunner is can anybody answer this please
> can anybody answer this ?
Yes, your local Yamaha water-sports retailer can answer it.
Jun 13, 2014 | Yamaha Boating
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
Need Help On A 1994 Yamaha Waverunner 3
Check your pump and impeller, then trace water inlet hose from back to front, possibly have a flush kit thats missing the cap?
Apr 30, 2012 | Water Sport
I downloaded angry birds on my pc. and i need to give a serial number for it,..how do i get the serial number?
namastey!
For Windows users, go to Start, and then Run. Type in regedit and click OK. The registry will open. Search for the game's title (CTRL-F). Hit F3 to continue the search if the title doesn't show up on the first page. If you look in the data column, you may see a long string of numbers and letters that looks like a serial number. Write it down and save it.
Aug 24, 2011 | Computers & Internet
Bike was stolen have title with frame serial number. Need engine serial number.
Oct 06, 2010 | 2003 Yamaha YZ 125
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Vin location
It should be located on the right hand side of the down tube. Turn the handle bars to the left and look on the right side of the down tube. If it is not there or has been filed off most likely it is hot.
May 20, 2009 | 2002 Yamaha YZ 426 F
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
69 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
