Hi krahul17,
I see that you want to connect a
BigTV to your
Y560 Laptop, I can give you a few details on what you can do to conenct a bBig TV to your Laptop.
- Your
Y560 has an
HDMI port on it and you can use
HDMI to connect an LCD TV to your
Y560 Laptop.
- In
Windows7 lower right side of your task bar you will see the
speaker icon right click on it and it will give you options, see below image.
- Click on
Playback Devices
- You should see the
sound window inside the window you will see a list of audio devices on your system, you should see your
HDMI first on the List with a Picture of an LCD TV next possibly will be your speaker which is set as the Default device the last should be Realtek High Definition audio device.
Right click on the HDMI and select set as
Default Device once
set as default device your
HDMI video and audio should work but if you connected your Laptop to the TV before you changed this settings you will need to
restart you Laptop for the changes to take effect on your system and also
make sure that the input for your TV is also set to HDMI to make everytihng work.
- And if you will be going back to using you Laptop only you may need to go back to the sound window to set the speakers as your Default device to make the audio come out from your Laptop Speakers.
I hope that this will be of help regarding your concern, have a nica day.
