Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
Posted on Jun 11, 2009
How can I clean my GE stove top burner and black stove cap???
Please help. I just purchased a GE Profile stainless steel stove with black stove caps. The stove caps are stained with something that I cannot clean with soap and water. Also the large burner appears to have burnt stains. All I did was boil corn on the stove top with the largest burner. I am very upset becuase the stove is only 3 weeks old. Do I have to replace the black cap or is it possioble to clean. I am leary about even using my stove now. Your help would be greatly appreciated. Joan
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2593
Points
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
I lifted the stove top of my hotpoint electric stove to clean under the burners and now I can not get it back in place
There are two metal brackets, thin ones, like little wires, one on each side, holding the stove top up. They are held in place by clicking toward you slightly when you life the stove top, push them back toward the wall slightly to release them.
Good Luck!
My gas oven wont light
The ignitor that lights the burner has failed...
Checkout this tip that I wrote...it will help uou understand your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
1helpful
Getting stains off burner caps on ge
Gently use a steel wool - or you can put all of the grate assembly pieces on self clean in the oven, wipe when finished.
2answers
Water marks on stainless profiles
I have used Bon Ami or Bar tenders Stainless steel cleaner (found in the section of Ajax or Comet Cleaner). Put some of the powder on soft cloth, wet it a little & scrub mark lightly; use clean rag w/water to clean off powder. Then use stainless steal spray cleaner (like the one found at Bath & Beyond) and rub in with soft cloth. I have found that the pull-out stainless steel cleaner wipes are too wet & just smear. Good luck
2helpful
3answers
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Ingiter won't stop sparking.
You might have cracked the electrode if you were scrubbing next to it, otherwise you might try taking a little sandpaper and scuffing off any residue on the top of the igniter and seeing if that does the trick. Good Luck!
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
