I have the Yamaha hooked up to a Sony and when I change channels using my DirectTV remote I loose all sound. The sound returns if I change the video source from DTV/CBL to something else and back.
If your using HDMI. The HDMI technology in version 1.1 & 1.2 was riddled with problems. Check your owners manual for version.Or, try the Coaxial Digital or optical output from your sat receiver to your Yamaha receiver, go into "GUI" "Menu" not sure which on the HTR series and Lock the audio input to Coaxial or Optical on CBL/SAT. Then Test. If it still has issues, check the settings for Audio on the SAT receiver and make sure they are correct. If you still have a problem, use a standard RCA from the sat receiver to the Yamaha. At this point audio should be rock solid on analog. Look on the back of your DSS receiver for the model # & write it down. Then go into the units menu "SAT" and check it's firmware version for version and date. It may need an update. Go to your Sat's website, Directv or Dishnetwork and go to support, enter model # and look for any updates that may apply. Hope this helps
