A simple circuit looks at the voltage that the alternator is producing, and turns thebattery light on if it is low. The battery light indicates a battery charging problem.
I had my clutch replaced yesterday on my renault scenic grand and now the battery charge fault is showing on the display and the battery has completely died
I had the same problem.I think oil or coolant got into the buttons,causing an electrical problem. I took the battery out and put a couple of drops of alcohol on the buttons and inside battery compartment,then blew it out really good leaving the battery out and drying under a light for about an hour.
Hello, try E-Bay I have found many batteries for many different products over the years. Or try researching through Google, quite often you can find a lot of suppliers for different batteries ect. I hope this helps.
Change or recharge the battery. Repair any exposed wires (insulation broken or worn off) on wires in affected circuit that may be shorting out and drawing current from the battery.
start engine and hold rpm about 1500 turn all light on and wipers heated rear windows the lot ,if engine stops the altenator is U/S if it all keeps working and engine running change the battery
becuse u set primary disaply as 2nd .and alsio there is resolution problem.
set that monitor with your frineds desktop and when u power up the computer Press F8 key then
u got menu then go to enable VGA mode.then change your disaply resoluiton.to 1024*768.
that it.
hi toffie! you probably have it connected it to your onboard vga, please have it check at the back if you have a video card connected separately, and if you have it means that you need to disconnect it on the onboard and connect it to your video card.
