The first question to ask is what have you got on your D: drive - do you have any movie files saved there? (.MPG .AVI etc) - if so, then these should be either copied to DVD media or to an external USB hard drive.
The next question is what operating system are you using? - if you are using Windows 7 then have you set your D: drive as the target for where Windows Backup should put it's files - if so, then go into the Backup settings and change the number of System images to be kept to be only 1 and also look at how many old backups you have got - you can delete some of the older ones to make more room.
Next, you could install the free
Advanced System Care utility software which provides a tool called "Disk Explorer" which will show you what large files and folders are on your D: drive and allow you to take actions to delete, move, put on CD or DVD etc to make more space.
Finally, once you have made more free space, then you would be recommended to do a Defrag of drive D: to improve the performance of the drive - again the makers of Advanced System Care provide another utility called
Smart Defrag which can help with this task.
If you are using Windows XP there is also a free utility called
Folder Size for Windows which works with Windows Explorer to give you an extra column you can select to show the size of folders on any drive.
