How do you manually defrost a Samsung RF261 refrigerator and how long should the defrost cycle last.
Defrost cycles in normal conditions can last from five (5) to 25 (25) minutes, depending on variables like humidity, runs times and how often the door is opened. Defrosting the unit manually as you've done is merely a short term solution as it recurs again over time. You should find out why it is not working automatically, as intended. This could be a problem with poor air flow (fan, blower or restricted air), a bad control, or even loose connections. Forcing defrost without correcting the underlying issue will not eliminate the problem.
