ACCIDENTLY PLUGGED AN AMPLIFIED SPEAKER WIRE IN THE SPEAKER JACKS ON THE BACK OF T.V. T.V DOES NOT TURN ON NOW.ACCIDENTLY PLUGGED AN AMPLIFIED SPEAKER WIRE IN THE SPEAKER JACKS ON THE BACK OF T.V. T.V DOES NOT TURN ON NOW.
I have the same problem , everytime i try to put it on, the green lights on the tv blinks and then shut down.It tries to go on for at least 3 or 4 tmies.I let it rest for about 30 seconds, and then try again, it take usually 3 to 4 times and it goes on and could stay on for the entire day . model D52w19 ul model ( D52W19b) serial no. E333C304R manufacture august 2004. If you have any solution , please contact [email protected] december 9,2007.I have the same problem , everytime i try to put it on, the green lights on the tv blinks and then shut down.It tries to go on for at least 3 or 4 tmies.I let it rest for about 30 seconds, and then try again, it take usually 3 to 4 times and it goes on and could stay on for the entire day . model D52w19 ul model ( D52W19b) serial no. E333C304R manufacture august 2004. If you have any solution , please contact [email protected] december 9,2007.
i keep trying and there's days that it will take a good hour for me to get the light to stay on. by that time show that i wanted to watch is over. my tv is only 4 years old!i keep trying and there's days that it will take a good hour for me to get the light to stay on. by that time show that i wanted to watch is over. my tv is only 4 years old!
try to turn TV on, green light comes on and then goes off, wait and try again, will take several times before light will stay on try to turn TV on, green light comes on and then goes off, wait and try again, will take several times before light will stay on
AnonymousJan 07, 2009
My tv turn's on and then off. The green light flashe's on and then the whole set turn's off. Please help. [email protected] rca MODEL D52W19 My tv turn's on and then off. The green light flashe's on and then the whole set turn's off. Please help. [email protected] rca MODEL D52W19
You can't post conmments that contain an email address.
Blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. check the components as given above and if necessary replace the components to solve the issue. This will help. Thanks .please do rate the solution positively
.thank you for using fixya.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair. http://servicemanuals.vstore.ca/
i have had same problem repairman states splitter is bad has an upgrade for $350.00 the next time repaior man could not find part,,advised he would have to replace entire box this cost $275.00 and also states thiis would be a later model than my original box,the picture is great never been this good.note when i say box i ment the box inside tv with all the electronice and projector
Horizontal output and the low voltage regulators should always be checked first in a set that wont power up. If you need a manual go to http://www.servicemanuals.net/. Be sure to check back if you need some help.
