I can see the Imogega Home Network Drive in my workgroup, including viewing the system info. I try to open one of the folders and I am told: \\Imoega-090c8b\pbsafebup is not accessible. You might not...
This (and other problems having to do with accessing the drive or its folders) can be solved by:
1. Removethe drive from its case
2. Plug it into a computer
3. Boot the computer to a Linux-based OS -- if you don't have a PC running Linux, download one of many Live CDs images available, e.g. Knoppix, and burn a CD with it (Live CD images are bootable), then boot the PC using the CD
4. Login as the root user and open a terminal session
5. If necessary, 'umount' the drive, e.g. 'umount /dev/sda2'
6. Run 'xfs_repair -L <partition>' where <partition> is the partition to be repaired - in my case it was /dev/sda2, so running...
xfs_repair -L /dev/sda2
...was the command to do the repair. Note that the command is cAsE sEnSiTiVe.
You may get a message about destroying a log file (that's what -L does) -- it's OK -- I've had to do this several times and no harm has come of it.
The process can take several minutes, and at the end there may be a message about a bad superblock -- this is also harmless, so far as I've seen.
7. Power down the PC
8. Remove the drive, put it back in its enclosure, and Voila! -- all should be OK upon booting it up!
