Question about Samsung TL110 ST70 Digital Camera
Flashing yellow light when charging - Samsung TL110 ST70 Digital Camera
Tip
Samsung SL202 Flashing Yellow Light Is your Samsung SL202 flashing a yellow...
Is your Samsung SL202 flashing a yellow light and not charging its battery?
This is an indication that your camera has decided it needs to completely discharge its battery before the charge cycle begins it again.
Rechargeable batteries last longer and perform better when they are completely discharged before being recharged. This is normal.
I hope that helps.
______________________________
SL202 User Manual here.
SL202 QuickStart Manual here.
on Apr 18, 2010 | Samsung SL202 Digital Camera
Battery light flashing yellow then green
A flashing yellow light usually means a low battery. When the light turns green, the battery is fully charged. It is helpful to list brand and model number because flashing lights similar to beeps from a computer, are usually brand specific codes which can be looked up on a chart to interpret.
Aug 11, 2015 | Computers & Internet
What does it mean when the scooter lights flash 8 times after it has been charged
Need more info. Name, manufacture of scooter or is it a wheelchair?
Sep 20, 2014 | Health & Beauty
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
I have the SSC-1500A battery charger and the yellow light keeps flashing. The yellow light is the charging light.not sure why
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
Sep 23, 2010 | Schumacher 400w Power Inverter
When do i know when the battery is chagered
On most chargers the light will flash when it is charging and stop flashing when it is fully charged. It may also have 2 lights that indicate when it is charged. Or it may have a yellow light that turns green when it is charged.
Apr 25, 2010 | Black & Decker BD12PSK 12-Volt Smart...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Samsung TL110  ST70 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
