Does playing the Xbox 360 use GB from your monthly quota or once you buy Live Membership does that cover the cost of playing?
The xbox live gold membership is paid for when you buy it. It never runs out until you have used all of the time you bought. Like say you bought a 12 month subscription it will last you the whole year until the day you bought the last one and activated it. Only time you use money is when you want to buy something from xbox live. All you need is the internet wifi or direct cable works. You can actually use your xbox live account on any xbox. Say if his friend has an xbox and has xbox live he can then use his account on his friends xbox to play online with his friend. You dont have to worry though every time he goes to an xbox he has to recover his xbox live account info so no one else can use it while he is using it. There is also a few new updates to keep his account safe as well when he does want to do something like that. also you can go into family settings and make it so he cant buy anything with out a pass code even put a timer on it with a pass code to limit time of play. So inclosing no you dont have to buy GB it just uses your internet connection and it does cover the cost of play for as long as you bought the subscription. Hope this helps :)
SOURCE: xbox live
Hi you will need to either do the following:
1. extend the dhcp leasing function within the router by increasing the time for the lease, usually this is in minutes
2. manually assign the ip address so ud ont have this problem ever again
3. renew the ip address via xbox 360
4. it could just mean the xbox live server is temp down.
good luck
smeags.
SOURCE: My son has xbox 360 live. Can he use my Sprint
You could try but that is not tested by the live group so I doubt that it will work. Aircard are not tested for xbox 360 consoles and if it will work, he might encounter issues for the multiplayer games and game lags. Try going to xbox.com for more issue for the compatibility of the service.
SOURCE: xbox live disconnects randomly,
Honestly the only thing i can tell you is that you have to make sure you have a secure cable connection make sure nothing is loose and is safe from being tugged by any objects if you are using wireless i'd suggest you use wires... if these don't have any problems there then the problems lies with your phone company...sorry if this does not help your situation
SOURCE: requires an xbox live membership with permission to play live
You shouldn't need the parental controls changed to log onto Xbox Live. However, since you switched computers make sure that your Xbox is getting connection to the internet correctly. You can 'Test Connection' in the settings tab of the Xbox home screen.
If you are getting the internet connection correctly and logging in with your normal Gamertag, you should have no problems.
SOURCE: xbox 360 can't connect to "xbox live party" for me or my friend
make sure u both have gold and make sure ur network doesnt have strict security
