The stay mode most likely follows the same exit delay that the away mode uses, try waiting a minute or two after arming in stay then try the front door.
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
That's the way the camera works. You can use the "Remote on Duration" command in the Setup menu to change the length of time the camera stays on waiting for a command from the remote, but if the camera times out then it will revert to non-remote operation. An alternative would be to hook up an external power supply and keep the camera from turning off at all.
you can turn of sleep mode.the machine will stay on all the time.
you enter sevice mode 1) Press the user mode key (star ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key (star ).
then option ......user.......sleep and you put on 1.
goodluck.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
It sounds to me like the printer needs repaired/replaced as the gears which drive the printer cartridges' belt are no longer aligning correctly. At today's prices, I strongly suggest just replacing the printer as you can get a new one pretty cheap now. Good luck!
