Washing Machine does not start
My washing machine servis caress 1200a, will not start after blowing a fuse, fuse has been changed but will not start.
    Scholar:
    New Friend:
  • 103 Answers
It could also be your line to the machine is fried at the ends where the electrical hook up is. Look at the connections on the back of the machine. One may be fried
Posted on Feb 21, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: servis 1200A caress washing machine trips electric
A wiring harness may be loose and the vibration has worn through the insulation. Put it on the side and take a look for loose wires and rubbing.
Posted on Mar 08, 2008
Anonymous
  • 3 Answers
SOURCE: Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Posted on Jun 24, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Can I get a a circuit diagram for a Servis caress 900 washing Mac
Thank you for your patience. I have searched thoroughly and unfortunately have been unable to locate a wiring diagram anywhere that falls under the numbers you found on the machine. I'm sure sorry and will continue looking, but it's like the wiring diagram/tech sheet for the unit you have is a state secret or something. LOL Again, my apologies and best wishes and I hope that you will utilize Fixya again in the future with better results. Thanks again.
Posted on Aug 26, 2009
Servis 1200a trip electric when motor is pluged
When a washing machine trips mains out, it is normally the heater element that has failed and it trips after it has filled with water as it tries to turn the heater on to heat the water.
Feb 06, 2015 | Washing Machines
User manuals for: Hoover soft wave model number HSWD 126-80 and Servis washing machine Caress 1000A, model no: M3101A If someone could help that would be great :-)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 22, 2011 | Washing Machines
Manual instruction for servis caress 1200 a
i want to connect a hot water to my caress1000`a`
is it possible?and how our washing machine could control the temperature.(washing machine has a cold water connection)
Aug 31, 2010 | Washing Machines
Their is usually a wireing scmetac inside the timer and switch housing of most machines.
Aug 25, 2009 | Washing Machines
Jun 24, 2009 | Washing Machines
How do you remoce the start switch on a servis caress M2010?
It's probably a broken lid switch.. There's probably an ovular hole under the lid on the right side. Here's a helpful link to access it.
http://www.applianceaid.com/procedures.h...
Jan 11, 2009 | Maytag Dependable Care LAT9706
No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Dec 14, 2008 | GE WPXH214A Front Load Washer
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Servis 1200A caress washing machine trips electric
Oct 30, 2007 | Maytag Dependable Care LAT9706
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
