Question about Lexmark X738de Color MFP
I have lexmark x738de printer, it showing error 956.02 how to fix that error
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
Cartridge error, how do i fix it?
whats error is it showing? cartridge missing or empty?
Aug 29, 2012 | Lexmark X4650 InkJet Printer
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Showing hardware error 0504
To fix this hardware problem, please refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display.
Sep 19, 2011 | Lexmark X6150 All-In-One InkJet Printer
Lexmark printer showing message unable to authenticate ink cartridge
If you have already tried reseating your cartridges and the error continues, make sure your printer is updated. The recent firmware update available in the Lexmark website at http://bit.ly/s405fw will help fix the problem you are describing. If error continues even after updating your printer, please contact Lexmark technical support. Thanks.
Feb 18, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Error 2200 with Lexmark x7170
Here's an article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link for instructions on what to do: http://bit.ly/deHk7F. Hope this helps but if all else fails, don't hesitate to contact Lexmark Technical Support for further assistance.
Jun 07, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer shows error 1200. how do I fix?
The error 1200 is caused by the cartridge carrier getting stalled. That can be due to several causes. Here's an article in the Lexmark website to guide you to identify and, hopefully, resolve the problem. Just click on this link: http://bit.ly/9QxkWP. Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
Apr 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
Shows there is no communication between laptop & printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Oct 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X738de Color MFP Logo
375 people viewed this question
Top Lexmark Computers & Internet Experts
Duncan Mutch
Shawn DuRee
ray gallant
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
