PDF
Roller Wheel Disc (older models only). 48. 15 ... change between "BIKE" and Elliptical ("ELIP"). 9. ... Replace the Brake Assembly on the Schwinn® 430/470.
PDF
Manual en Espa?ol Latino Americano: http://www.schwinnfitness.com. 430 / ... If replacement parts are necessary, use only genuine Nautilus replacement parts and ... PEDAL TO CONTINUE (if a bike) / STRIDE TO CONTINUE (if an elliptical).
The Machine Type switch (N) on the Console is preset at the factory to B (bike) or E (elliptical). If you replace the console,. it will possibly be necessary to set the ...
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
I took a magnet from a magnetix toy and secured it to the correct side of the flywheel. It's working now...I just finshed doing it. Hopefully it'll continue working. Thanks for pointing out the magnet was on the wrong side.
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
sounds like the sensor is loose or bad.I have the same schwinn 430 elliptical and my speed stayed at zero and after a couple minutes it would shut down.i called schwinn bowflex and they sent me a new sensor ($2.00)since my warranty expired and i installed it(not fun) and thats what fixed it. im back to working out.
