Hi, I have a portabel air-conditioner that for no apparent reason started rattling approximately 1 minute after i started it. If i remove the the exhaust hose the rattling stops. But it is not the hose itself. If i partially cover the air outlet where the exhaust hose attatches the rattling starts up again. Any suggestions appreciated.
The rattling noise is most likely caused by a structural issue--a misaligned fan, loose panel door, a broken motor, or debris on the unit. If the fans are not aligned, you can adjust them yourself by opening the panel door and fixing the screws on the fans.
Not sure i use mine without exhaust hose
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
SOURCE: Amana AP125HD Portable Air Conditioner This
I have this Amana/Haier unit. I recommend reading the Owner's Manual because it actually discusses this issue although a bit indirectly. I've used the unit in Mississippi, and it's voltage and surge sensitive, and the Manual implies.
So, when the Manual says to put the unit on its own circuit, and to make certain that the circuit is also fully capable of supporting the electrical load, including the full amp load noted, it means it, in my experience. I even had to ditch a work-around long extension cord (albeit a heavy-duty, rated one).
The long term solution was making sure the machine was getting clean, non surging, non sagging AC power on its own circuit to the main board. And then ... it's worked flawlessly in heating, cooling, drying and ventilation modes.
One last thing ... the Manual is also serious about leaving the unit to sit still for 12-24 hours if it moved and rotated from the vertical. If fhe oil moves inside and can't resettle, it can also trigger motor shutoffs.
I hope this is helpful for enjoying what seems to be a well built machine.
SOURCE: My portable air conditioner Model
Yes it sounds defective from fatory and should be exchanged.
SOURCE: Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
SOURCE: Air conditioner is rattling after
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner,
the first thing to check is whether the unit is getting proper power.
If the unit uses 220 volt power be sure that the proper voltage is
getting to the unit. Same for 110 volt units. A voltage meter can be
used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat.
If voltage is being supplied to the thermostat but not from it then the
thermostat probably needs replaced. This is a fairly common problem.
Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor
may run for a short time, but will overheat and shut off. Continued
operation like this will result in compressor failure. This motor can be
economically replaced for larger window air conditioners, but for
smaller ones the cost of replacement will be more than a new unit.
Central air conditioners
for the home are more complex and there are more things that can go
wrong. As with the window air conditioner the thermostat can also be a
problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The
next thing to check will be the indoor blower. If your thermostat is
calling for cooling then the indoor blower should be running. If there
is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil.
This can happen for a few reasons. The indoor blower is not working,
the air flow is restricted and not allowing air to move across the coil.
A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As
you can see there are many things that can go wrong with an air
conditioner and I have not come close to exhausting the possibilities
here. I have just touched on the most common problems in a very basic
way.
There are some basic trouble shooting things that can be done very easily. Most
problems are above out of the range of comfort for many homeowners and
professional help should be consulted before any attempt is made at
repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Just to clarify, i have used this unit many times before without problem. Then, one day it started rattling.
Also, it is NOT an amana brand, it is a "domain air". I
Are they really good in use? Im thinkin of getting a new portable air conditioner to my office but I read about it and people say they are quickly shutting down.. What do u think?
Hi guys, thank you for sharing all this information. I dont know so much about portable air conditioners but I guess there is a link that may help you to find it out. I remember when I was choosing an air conditioner my home, this link Homeairadvisor helped me much to learn all the important things about air dehumidifiers and air purifiers, pros and cons of that and choose the one that please my needs. For me the number one priority is to make my home a good place for living with a pure air inside!
