Belkin (F5D7230-4) Router (587009) Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get the Belkin 54 Router with my laptop to connect to the internet - my laptop gets the router with excellent connection but when I go on the internet it says Page Not Found each time - what can I do?
Michael Galve
Level 3:
Genius:
  • Master 1,269 Answers
  • Posted on Jun 10, 2009
Michael Galve
Master
Level 3:
Genius:
Answers
1269
Questions
0
Helped
426677
Points
3247
Try to reconnect to your wireless network, if it asked your for a network key, make sure to type it correctly. You may also try to power cycle your router.
2helpful
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
2helpful
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
